70bigblockdodge
I don't know WTF he is talking about oil pressure. The galley is in the same spot on all B and RB engines. If your pushrods that came out are tapered at the bottom, or top if you have it upside down, you will need new pushrods you will have to go find 67 down lifters easier to change pushrodsDave: I just now saw this post. . . Does this issue also apply to the early '66 440 engines? As you may know, I'm having one rebuilt, and it will have a new cam and lifters.
Edit: friend of mine has a 413 in a 64 Polara started clacking he pulled V.C. and found a non spin lifter and taper pushrods. He put a used lifter out of a 340 in and put the taper pushrods back, and went racing. Anything will work for a while.
