Check your sending unit with an ohmmeter. Original sending units are as follows as would have been seen on the original gauge low first line should be around 74 ohms. Middle line around 23 ohms. Hot mark all the way to the right should be 10 ohms
So if your sending unit is reading lower than 74 ohms give or take 10 ohms it is likely your sending unit.
Check again when your thermostat first opens. (You will feel heat in the top radiator hose and radiator). It likely should read around the 23 ohm mark. If it is reading lower,more than 4-5 ohms less than 23 ohms, your sending unit may be reading high. Make sure your thermostat is opening at around the 180 degrees or whatever value your thermostat is.
Sorry I don’t know the exact table of ohms to degrees. Just going off factory gauges.
