There wasn't any directions when I got my heads.I'm not getting into a argument with idiots that can't, don't, & won't follow directions! RTFD
Agree, what was done here is the same as buying a set of swap meet heads that someone cleaned up really nice, and are laying in the dirt and grass, holding the night time tarp down. Taking them home and bolting them onto a engine with nothing more than a wipedown. Who would do that?I would never install new heads (no matter what brand) without having them checked out by a reputable machine shop. Cheaper than damaging a motor and having to disassemble and repair.
I had a piston smack the valves a the head was intact. When I removed the keepers, those were tight as hell. And I never did any prep, just bolted then on and went. Should you check them out first, probably. But I love how someone spends $1000-$2500 for a set of heads, and then is supposed to go spend $400-$700 more to make sure they're ok.
Did you have the Eddy's checked out? If so, were they perfect right out the box?
Well then you obvisoly didn't read everything 440source has to say about warranty and installation!There wasn't any directions when I got my heads.
Your barkin up the same tree I am!!!!Agree, what was done here is the same as buying a set of swap meet heads that someone cleaned up really nice, and are laying in the dirt and grass, holding the night time tarp down. Taking them home and bolting them onto a engine with nothing more than a wipedown. Who would do that?
There is a expectation that being new there should be no issues, but you know what they say about assumptions.
I like that, and I agree.My machinist has a saying "if it comes out of a box, it's fkd up
That's nice, but you can interpret that many ways. Swapping the heads in my driveway and being on a shoestring budget, I looked them over and made sure there wasn't any loose material from machining. They worked fine until the connecting rod broke, and the piston bounced off the valves. I will check out the next set of heads I get, and I'll rebuild the set I currently have.Please note, you must check over all part(s) to your complete satisfaction before they are used.
Well there is your problem.They worked fine until the connecting rod broke, and the piston bounced off the valves
Already have the 10° retainers in the shelf.You are aware that they use 7* retainer locks and that they recommend anything over a 510" lift cam to use 10* locks don't you? I'd really hate to see you screw up things even more than they are now because your not paying attention!! Good Luck
Read about it here on both intake & exhaust vale locks.
Stealth Aluminum Cylinder Head - COMPLETE - SINGLE HEAD-440 Source
When you say checked, what is being checked, what needs to be checked?I would never install new heads (no matter what brand) without having them checked out by a reputable machine shop. Cheaper than damaging a motor and having to disassemble and repair.
I was hoping that new, off the shelf goods were bolt and play
