Anthony 71 Paisley
Good Morning all. My inexperience leads me to a question. I am in the middle of having 440 built for my 71. .060 over , stealth heads with bowl work ( still to be completed), 1.5 harland sharp , Icon 9953 pistons should put me right around 10.5 ish . Kinda loosely based off the LOWLY 440 build. My question is this
I am going with a Bullets recommendation ( not sure if everything they do is custom or if its a shelf part but they are out of stock ) but the specs seem very similar to me as a 509 cam except a little more lift . Mine will be a hydraulic roller though. I understand that less friction is better but I always hear about faster ramp speed as being the benefit ( also break in ) to a HR. It may be my inexperience but i don't see much difference between the 2 cams . I guess having the timing events would help to see a difference but looking at them on paper i wouldn't know the difference anyways. Will the HR be that much of an improvement over the purple shaft?
Bullet
Intake
242 @.050”
.347” lobe lift, .520” with 1.5 rocker
298 duration @.006”
Exhaust
248 @.050”
.344” lobe lift, .516” with 1.5 rocker
305 duration @.006”
112 lobe separation
108 intake centerline
@.050”
IO 13
IC 48
EO 60
EC 8
Mopar Purple
Intake Duration at 050 inch Lift: 248
Exhaust Duration at 050 inch Lift: 248
Valve Lift with Factory Rocker Arm Ratio: 0.509 int./0.509 exh.
Lobe Separation (degrees): 114
Bullet
Intake
242 @.050”
298 duration @.006”
Exhaust
248 @.050”
305 duration @.006”
112 lobe separation
@.050”
IO 13
IC 48
EO 60
EC 8
Mopar Purple
