'61 - '66 Imperial front disc brakes - has anyone done this?
I did a little checking on this for you. 1966 thru 1973 Imps use the same wheel bearings (A3 - A5). 1969 thru 1973 use the same rotor (27111). 1969 USES A FOUR PISTON CALIPER. 1970 - 1973 use the same caliper (508 - 509). I would try to find a set of spindles from a 1970 thru 1973 imp.
The problem of wheel bolt pattern arises after 1973. There is so little in common with the '56 - '66 Imperials and all other Mopars.
Thanks for the tip, 55.
