65 2door Fury Rear Seat Removal
dammstrate
Minneapolis, MN
Getting the seats redone on my 65 Sport Fury. Can't figure out how to get the rear seat back out. Got the bottom cushion out now problem. What's the secret push/pull move?
My Newport has two bolts at the bottom of the seat back, remove them, then push upwards if yours is the same.
Yup. Same as Newport. Remove the two bolts and raise the seat to unhook the top. Make sure you remove the arm rests.
Like they said - unless you have the sculpted package tray, then it's remove the bolts and slide it down and out.
Edit: Just saw your photos and no sculpted rear so should just slide up n out.
