'67 Fury Throttle Cable Inner Wire / throttle pedal
Furyus67
Baltimore, MD
Does anyone know the size of the ball on the throttle cable inner wire that connects to the throttle pedal. I want to purchase the Lokar throttle cable and the ball size is 3/16. Does anyone know if this will work?
Thanks
Josh
I'm interested in your experience with the throttle cable in your fury. I recently acquired a 1966 big block fury and the previous owner installed a universal throttle cable. There's not much space and where it bends coming out of the firewall it's kinked and the throttle is thus very stiff. Were you able to find a solution to your problem?
Thanks
Josh
I used the Lokar throttle and kickdown linkage for my 66 Polara 440 4bbl car. It took some adjusting but bolted up pretty easily. Summit Racing actually sells a cheaper set of cables that is made by Lokar.
