- Joined
- Nov 14, 2010
- Messages
- 28,555
- Reaction score
- 28,406
Check the fuel pump pushrods in the '73.
About half way through, I gave up trying to read it.Please don't put an Edelbrock on it there junk best to go with an QFT carb and a lokar kickdown set up I had an Edelbrock on mine put your paper absolutely garbage replaced it with my QFT 780 CFM carb and I've never had another issue it's amazing coupled with the 24 hour customer support and the superior build quality it's just the right choice Edelbrock has no place on quality vehicle
It's OK to be scared of change but you guys need to realize straight drop on things aren't always the the best
I've given Edelbrock plenty of chances but they're poor manufacturing fit and finish and overall quality is horrible.
And the funny part is my 780 ca and the funny part is with my QFT 780 carb my car runs perfect it doesn't bog down at all doesn't blow a even whisper of smoke.
Do you want something done right or do you warning done cheap ?
All I know is that my 67 never ran better thanks to all the advice from my buds here on the forum! Also, I'll be putting a new Eddy on my 73 in the spring too! Sorry minuette...
What should I look for in the push rod on my fuel pump Matt? And why?
I called them poorly manufactured because their valve covers rub on the push rod assemblies the carburetors are horrible no matter how much you adjust them their water pumps like to shed the belts and I didn't put the Edelbrock on it the previous owner did
But due to the Poor manufacturing that I've dealt with I would never use one again swapping over from an Edelbrock to a quick fuel Carb I save $100 in gas per 700 km.
One of the first symptoms that reared its head in the fuel pump pushrod issue was increasingly hard starting when hot. I think it was a combination of vaporization of fuel in the carb after the engine was shut down and the fact that at cranking rpm the short throw on the fuel pump was having a hard time refilling the carb. At cruising speeds the engine turns enough rpm that the shortened rod can keep up with demand. The affects were most obvious during hot starts and under acceleration. My pushrod ended up almost 3/8" shorter from wear by the time I discovered it.All I know is that my 67 never ran better thanks to all the advice from my buds here on the forum! Also, I'll be putting a new Eddy on my 73 in the spring too! Sorry minuette...
You say I don't have direct experience with Edelbrock's I do (10,000 km on carb )they are junk in my opinion that's why they aren't on my cars anymore no mechanic in the land could get them to work properly. Quick fuelbtechnology carbs I put 10,000 km on one of those as well Quick fuel technology carbs without a hiccup it was absolutely brilliantOK, so what vehicle and engine were the Edelbrock parts on - and you say they were installed by the previous owner, not you? So you really do not have any direct experience with the Edelbrocks and further, you know nothing about what might have been done to the carb by the previous owner, nor whether it was the proper application. I really doubt Edelbrock valve covers will interfere with a stock rocker arm setup either - never heard that complaint (are the rocker arm assemblies aftermarket for some reason, if you even know)? It seems you easily indict a product when you have no real basis to do so. You are alone in your criticisms, at least so far. So everyone is wrong but you. Fine.
