Walter67
Is the rear main seal on a 1967 Plymouth 383 rope or rubber? I understand oil additive to eliminate oil leaks will not work on a rope seal.
Did either of you guys have to loosen the caps of the con-rods?
I had to.
My crank was in too tight and I had no wiggle room to snake the upper half of the seal thru there.
Yes. It sucked.That would take the job to the next level........ouch
It should be mandatory that you put one in backwards once in your life. To teach you a lesson you'll never forget... See reply #7 above.Also the lip faces inward toward number 5 main bearing
