For Sale '67 steering column
detmatt
Feedback: 29 / 0 / 0
Says '67 Fury II right on it, see?
I just want it gone so $40 + shipping as is from 48073 but I would love it if somebody local needed it so they could just come and get it.
What makes you say that?
A column shift for an automatic car would only have one shift arm on the end. Yours has two. Try the shift pattern and see if it is for a three speed. I bet the shifter pulled back will work one set, and normal will work the other. If not then the column has to be for a 1965.
You're correct sir, this is a manual shift column.
Would be a great start to a floor shift conversion. Whack the shifter nubnoff tge collar, and fill the hole with JB weld. I done that plenty of times.
