Thank you, I will look at the site you suggested for the wiring diagram. I ordered a factory service manual but it has yet to arrive.the engine stuff comes off the bulkhead plug and goes to the right across the firewall ...the headlight stuff runs down the left fender to the front of the car...think they both come off the same plug but not sure...have to go down to the car and check...top plug is wipers, maybe middle is engine compartment and bottom is rear of car? a wiring diagram will confirm it...you can find one on MyMopar.com...got people coming over any minute so might not be able to check it out till tomorrow
Rainy day where are you located?I am parting out 6 1968 Fury's if you are needing the harness.
I am in the San Antonio Tx areaRainy day where are you located?
