68 Newport. Tightening up the steering
Biggredd2069
Parker, CO
Guess this would be a drive line question. I've rebuilt my steering pump and my steering gear box. New pitman arm. And some new bushings. I just can't seem to dial out a ton of play in the steering wheel. I know it'll never be rack and pinion but there's gotta be a way to tighten it up to not be able to have so much slack in how much the steering wheel can go back and forth between and 11 and 1. Just have this and rebuilding my heater core and I'm relatively happy with the car otherwise now.
Also look at the input side of the steering gear for in and out play in the input shaft on the box as it is turned from the center position. A wear point that can be adjusted with that big spanner ring on the gearbox. That plus the coupler and other steering column/gearbox interfaces.
Did you rebuild thI box, or have it done?
Was it adjusted properly?
