69-70 C body rear ends.
BrooklynBeer
Springtown, TX, 76082
Starting the brain work on the latest of a new project. Finishing up a 1970 D200 farm field find.
First off i don't have a car yet. But i am beginning the search for a 69-70 Fury. Or a same year Polara or even a 300.
Goal is going to be to make a step above factory street car in performance. (Think Fury GT) Just enough cam to know it's there, late model open chamber heads, no more then 10-1 for 92 oct fuel and most likely go EFI. (I have never done EFI)
Every 3 years i start something new.
Being most of these cars I am seeing are non sure grip, what rears are a direct swap or am I looking and just swapping a sure grip into the factory rear?
My only C body experience is the 63 Dodge 880 I use as a parts runner with push button and 361.
The third members on all of the 69-70 C-Body 8.75" rear end will interchange, do not waste time on trying to build an 8.25" rear end. For serious performance you should use the Dana 60 rear end. A big block car will have the larger diameter u-joints. If you are going for moderate performance you will want either a 3.23 or 3.55 gear ratio. Most 69-70 C-Bodies are heavy enough to where turning the tires over is not that much of a problem unless you are going for 400 or more horsepower.
Thank you. Just finished up going over the dana in the D200. I was wondering what i should be looking for as a direct swap?
The pickup rear end is wider and you will likely need to reposition the spring perches. If your Dana has 5 hole wheels on it, it was for low GVW applications and will not be the full floating type. We used an 8 lug full floater Dana in some of the racers years ago. As I recall, we had to shorten the axle tubes and the axles for racing applications that specified full floating rear ends. The D 200 usually came with 4:10 gears which are going to be unsuitable for street use with an automatic, your engine will be beating it self to death.
I have no dreams of using this dana from the truck in a C body. It has 8 lug axles to start and factory 3.54's. Basically this truck fell into my lap and i used it as a learning tool in rebuilding the 727. Just curious as to what other rear could go into the 69-70 C body that is a little beefy but not needing much work on it to see it happen
There is a chart on a bunch of different sites that show the rear axle width changed from 69 to 70 for C bodies but I don't know how accurate it is. I know for sure the 65-68 C body rearend is 56 3/4" and 46" perch to perch, which is almost identical to the 70-74 E body rearend. The chart shows that 65-69 are the same and 70-73 C body are the same, but that is a little suspicious because the C body changed body styles and went from slabside to fuselage in '69.
There were some changes from 1969- 1970. If you look at a 1970, the shackles are offset and the shackle mount is wider.
From what we've been able to figure in past discussions, the 1970 rear is 1 1/4" wider than the 1969 rear and the shackles are offset 5/8" on both sides.
FWIW, in 1970, they started using the rubber mounted front stub frame on some cars, although IIRC, the 1970 Plymouth got the solid mount stub frame in all their cars. Also, the shackles for 1970 aren't available new anywhere, but that's getting off the subject.
That makes sense, thank you!
