'71 300 coupe driver's window restoration
Rubatoguy
Portland, OR
Anyone want to guess at which components will need to be replaced? What is a good source for them? I am guessing I will need new guides and wipers at minimum. The window needs adjustment as well because at full up the front and back edges are not properly aligned with the back quarter window and roof.
I checked Vans and Detroit Muscle and neither had anything for ‘71 C body. Might want to go ahead and pull the door card and visually inspect for broken rollers/sliders. Also you would then be able to apply some spray lube to all moving parts. I like Blaster MultiMax.
