Hey Fellas... finally got to playing with the car. I found the Blower motor resistor connection (under the dash or easier if the ashtray is out of the way).
I did get the chassis manual and studied section 8 Wiring diagrams. I am confused.
My goal to to get the fan working on high and medium because low is well, too low. Right now, If I press-in the A/C to turn it on, I get low fan and no way to adjust it. I want to put in some aftermarket switch as my dash switch is bad.
Anyhow, I want to figure out how to connect it. what leads should contact for each of the speeds? I know brown is low, light green is medium and dark green is high.
I used my test light to check for what is "hot" with key on and a/c on and off. Please see below for my results. Hot means test-light to ground and "Hot between" means test-light between two points.
The PO did a number on my under-dash wiring and I'm hoping the mess I see is only from the radio swap but I also had what looks like an extra hole cutout on my temp panel and a small switch installed. I now have that hanging under the dash so I can have my dash together while I figure this out. It's connected to two light blue wires and I can't tell where they go but the switch does not seem to affect anything. sliding my temp control does nothing (cable bad)
I don't want to just start jumpering things together as I see in the wiring diagrams there are resistors involved and I don't want to blow anything (other than sweet cool air lol).
Sooooo, what do I do to get select-able air flow? I don't want to try to pulll or replace stock dash components as it looks like a pain just to get the controls out. My heater control cable is shot but I am likely to just rig some alternate way for that. Love my car but I am ok with a bit of McGiver-ing. As always, appreciate any and all help
