Now it's on Craigslist, has it gone full circle? Or did we miss the auction?
1972 Mopar Chrysler Town and Country Station Wagon - $10500 (Leland)
Might as well do the pics (again?)
title status:
clean
1972 Chrysler Town and Country station wagon with third rear facing seat for 9 passengers. Purchased from Prescott Brothers in Mendota IL. One build sheet was removed from the back seat but there is another under the third seat but it is jammed under the heavy bracing of the seat frame. 2nd owner. 44,897 original miles. Original 440 engine (still has factory paint marking on right side valve cover) with 727 transmission. The daughter of the original owner told me this car was only used to haul her fathers drum set around. It was not the family vehicle. Original woodgrain ( there are some scrapes and scratches to the woodgrain) and paint accept on the lower body which was repainted to eliminate rock chips and 2 small rust areas in front of the rear tires. Excellent original interior with original floor mats. The only part of the interior that could be repaired or replaced is the headliner. It has a 6." tear in the right rear corner a few small holes. The rear plastic is also faded in some areas. PS/PB, cruise(works), rim blow steering wheel, tilt telescoping column, A/C with auto temp(doesn't work), reclining passenger seat, 2 position tail gate with power window, search tune AM/FM radio that has automatic station selection by pressing either of the bars marked "LOCAL" or "DISTANT" or by foot operated button. Restored by Joe's Classic Car Radio with FMR-2 conversion. Low fuel light, seat belt buzzer, map light and key light. New rear brakes, hardware, seals, shocks and stainless steel brake lines. New front brakes, seals, calipers, hardware and rubber lines. This is only the second set of brakes on this car. New firm feel steering box from steer and gear, idler arm, pitman arm and tie rod ends Original radiator restored not just recored. New master cylinder and rebuilt power brake booster. New NOS correct fan clutch, new water pump, thermostat, belts and hoses. New correct NOS orange plug wires with a 1978 date. I couldn't find a 1972 date. It still had the original 1972 dated plug wires on it when I got it. Rebuilt power steering pump and new tires. Cleaned and restored original fuel tank, sending unit and carburetor.
This is an original low mileage station wagon that runs and drives great. $10,500.
May consider reasonable offers from serious buyers.
For more information call Rich 815-790-(see ad)
post id: 6653440659 posted: 2018-07-25 6:51pm updated: 2018-07-26 6:00pm
