727 Rebuild Suggestions....
1978 NYB
Warfighter
Legendary Member
Classified
I'm going to rebuild the 727 in my Newport myself. Does anybody have any suggestions on upgrades? I don't know if it is a lockup or not until I get it apart.
My fender tag says the car was built May 17th, 1978. It's a late production car so I'm assuming it has a lockup converter.
That's a great topic to start... I'm.going to be going through mine as well! im planning on using alto reds for the cluthes use a no flip rear servo. use and aftermarked plate to increase the forward clutch capacity. replacing all the bushings ect. block the accumulator and usea 4.2 kickdown lever w a better strut. prob a bolt in sprag and maybe a tf-2 shift kit. Just my plans... im not an expert.by any means.
Lockup? I learn something new every day. I thought the only lock-ups were 904s and 518s. Are lockup converters retro-fittable to earlier transmissions?
Whatever you decide, make sure to show us lots of pictures. I'm a little ways away from rebuilding my trans, but I'm leaning towards doing it myself, too.
I am rebuilding the 727 for my Barracuda right now I can try to post some pics. I did my brother in-laws trans for a 71 340 cuda it works well, I think it should shift harder but he didn't want it set on the highest level of the b&m shift kit, I like them to go BANG!! All I used in his since the car is stock is a ATP kit I bought off rock auto and a kevlar flex band from mancini, although I'm not using one of those in my transmission I got a band from my local trans guy that he uses in his diesel builds, Reybestos pn rps38961it seems sturdy time will tell. I think the 4.2 lever is a good choice the strut upgrade is a no brainer also the overrunning clutch/bolt in sprag is a good insurance upgrade for the $, I would use a trans go shift kit
Lockup? I learn something new every day. I thought the only lock-ups were 904s and 518s. Are lockup converters retro-fittable to earlier transmissions?Whateverr you decide, make sure to show us lots of pictures. I'm a little ways away from rebuilding my trans, but I'm leaning towards doing it myself, too.
I think you would be better off trying to find a BB lock up trans and putting it in, I got a cool pdf file I downloaded to my phone from www.mymopar.com tells you what the trans came from using the numbers on left side of pan rail. I know that if you can see the input shaft there is a snout sticking out in front of input splines, I would guess that if you found a small block 727 lock up you can tranfer inne
Different input shafts but is do-able with the right parts.
Torque converters are different too.
The lockup vs std 727s differe a bit inside, and I think the case is different too because of the switch and fluid path. Not sure, but I think so.
In terms of advice - Get that rebuilding book, look up Bulkpart.com, buy the rebuiild kit, the bushings, a TF1 transmission shift kit, and rebuild it. That will handle pretty much anything you throw at it until you start topping 450-500hp. Then it might need a different shift kit. The basic 727 is unbelievably strong.
I thought that was implied by the input shaft being different.
78 and up can have either type of input shaft, thus convertor. According to the bible.
You're right......but my Newport was a late build (May 5th) and probably has a lockup. Won't know until I take a look or cipher the code on the case. Everything Mopar 1979 and later had lock-ups.
