Both Eddie and Demon are good carbs. I've always used the Eddie 1406. Plenty of CFM's for a stock Mopar big block.
The 650 is also jetted differently. And that jetting seems to be perfect on engines from the smogulated era.I also believe they are both Cfm rated differently, pressure drop, wet, dry etc.
I think the demon carb has boosters in the secondary, the TQ does not making air door tension adjustments critical to smooth operation(sound familiar).The boosters can also be a cause for reduced Cfm ratings but should make a more precise mixture calibration.
With distributor cap off twist rotor it should spring back. Get a vacuum guage and set timing to the highest vacuum reading you can get, you may have to compromise if it gets much past 15° because of kickback on start up but worry about that when it comes up.
Thats setting timingOk, I will pick up a vacuum gauge tomorrow. Will i be connecting vacuum gauge to the vacuum advance while Im seyyong timing?
No you disconnect the vacuum advance and connect the vacuum gauge to manifold source. You will probably end up with about 12-14° btdc initial.Ok, I will pick up a vacuum gauge tomorrow. Will i be connecting vacuum gauge to the vacuum advance while Im seyyong timing?
No you disconnect the vacuum advance and connect the vacuum gauge to manifold source. You will probably end up with about 12-14° btdc initial. You could do a quicky advance till it starts to idle badly and back up a touch.Ok, I will pick up a vacuum gauge tomorrow. Will i be connecting vacuum gauge to the vacuum advance while Im seyyong timing?
You seem a tad discombobulated this morn...No you disconnect the vacuum advance and connect the vacuum gauge to manifold source. You will probably end up with about 12-14° btdc initial. You could do a quicky advance till it starts to idle badly and back up a touch.
