I recently converted my 77 New Yorker from Auto Temp II to manual controls. It's been done before and there are some threads here already about it, but I figured I'd share my experience as I may've done things a bit differently than others.
First, the lead up to this...
I got my 77 with a non-working Auto Temp system. Actually, it would do some things, occassionally, but never what was asked. But usually it would just do nothing.
I was hoping to get it working, and in fact put considerable time and some money into that. I even went so far as to purchase a testing tool to help troubleshoot. First thing I discovered was the pushbutton control was shot, it wouldn't hold a vacuum at all in any position when I tested it. Knowing that was definitely bad I bought a new one. That one tested perfectly, held a vacuum in all positions indefinitely. I thought I'd put that in and it'd be good to go, but unfortunately not. With the testing unit, I could run it through all the modes. All the doors would open/close properly, fan would adjust, etc. But without the tester, it didn't work. All the sensors tested good so I figured it was a bad amplifier. I was prepared to buy a new one of those (or get mine refurbed) but then I discovered the servo itself had problems. It seemed to move just fine but I could hear a hissing coming from its vicinity. That basically clinched it right there. I was done throwing time and money at it. So onward with the conversion.
