8 3/4 pinion seal and rear axle collar adjuster
mgm1986
Pittsgrove, NJ
Hey folks, waiting for parts to get the motor back together so I decided to tackle the pinion seal leak.
I have the 742 case and a few things I need clarity on.
For the 742 case, is it true it should have a solid spacer with shims for the pinion and as such I should be able to replace the seal and reassemble without worrying about changing the pinion gear lash?
For the axle stubs, only the drivers side had a locking tab on the rear axle adjusting collar. Is it correct that only one side requires the locking tab on the axle?
Thanks for your expertise!
Yes both are correct.
You can still overtighten the nut. So mark the nut on the shaft so you are close.
Axles are butted up to a centering block so they both move as one, so only one side needs the adjuster. Have both rear wheels off the ground when adjusting.
It's not that hard to adjust, don't make it harder than it is by overthinking it.
When you adjust the axle end play, do it when the car is cold and iirc, you should have .013-.023" end play. I've always done it by feel even though I have a dial indicator and never had an issue. Just make sure you don't get it too tight. When the axles get hot, they do expand and will close up the gap. If you have a service manual, the numbers will be in it.
the new pinion seal I installed 2 yrs ago was a rawhide one (NAPA? Rockauto? don't remember) and it still dripped a bit...when I installed the Sure Grip I used a rubber one from Dr Diff an it's been dry so far...iirc the earlier end play spec was looser than the later one so I picked a number that was acceptable on either scale
742 case uses shims to set the pinion bearing preload --no spacer -- remove your yoke ,,remove the old seal and clean the seal bore ,, install the new seal with some grease on the rubber seal lip ,, reinstall your yoke and tighten down the nut with loctite on the threads -- factory spec is 240 lbs/ft . as you tighten the yoke down to spec do it in steps of say 50 lbs/ft and give the yoke a spin back and forth each time ,,,, this helps to line up the bearing and race without binding them up ,,,,, as far as the lock tab ,,your adjuster to set the bearing end play should be on the RIGHT side axle ( passenger side ) only ,, if it is on the LEFT side (driver side ) someone switched the axles side to side from the original factory install. there is no lock tab on the LEFT side axle shaft.
All good advice for sure.
For others reading along, don't use an impact to get the nut back to where it was. You'll snap the threads off the pinion gear.
Time for a new gear set. That's what I get for rushing the job and not using common sense. Maybe this will tilt my decision to upgrade to a sure grip eaton setup and shorter gears than the 2.76.
:BangHead::mad:
:BangHead::mad:
How big of an impact were you using?? 3/4" drive? I've done a lot of work on 8 3/4's and have never done that but I don't use the big impacts.
Yeah, definitely too much torque from the 20v dewalt impact. I was half a turn from lining up my marks when it spun the nut clean off. A real shame, the gears look brand new. Now I get to learn how to rebuild the whole carrier.
I knew better and still went against my prior knowledge and instinct. A clear case of not learning from past mistakes.
ouch...you were probably trying to line up the marks a full turn tighter
I'm thinking it was probably already weakened. Do you know if a driveshaft ever got spit off of it?
Doubt that could happen....
Good questions. I do not know if it ever had issues in the past and I don't think I went a full turn tighter BUT it is possible, I don't think using an impact was a good idea. I should have taken my time, secured the case properly and manually tightened it. My dumb mistake trying to hurry the job cost me.
Now I get to shop for parts and decide if I am going to upgrade the gear ratio and if I should go with a sure-grip to give me a little more traction off the line. I think going from the 2.76 to the 3.23 would be a nice upgrade.
That's a bit more than a 15% change and you should feel the difference at the hit of the throttle.....and I would recommend getting a SG.
Yeah, at this point it just makes sense. With the 2.76 and one wheel it would spin like crazy from a dead stop!
I am actively researching the sure grip on the Dr Diff website. I think the link below seems like a good option but it says "Out of Stock" so I probably need to contact them to see if they still offer it.
Mopar 8 3/4" (8.75) Helical Gear Sure-Grip ("Sure-Trac")
Keep in mind that anything new you get will most likely be from China. Also depending on the gears you get, pay attention to the radius at the bearing fit. Shim fit is important there as some of this overseas stuff will have a larger radius and can interfere with the shims. A larger radius is good but only when the originals were bad and that didn't happen. I ran into that with a set of Dana 60 gears some time back and same with the SG unit. You're ok with the 8 3/4 unit since you don't need shims with the back lash setting. Just make sure your shim fit flat on the back side of the pinion gear head or it will play havoc with your pinion depth. Dr Diff had the larger ID shims for this mess.
did it destroy the threads on the pinion or just tear the threads out of the nut and leave that metal in the pinion threads? i would think the steel alloy of the pinion would be a lot harder than the nut and would hopefully survive...
I must re-emphasize what Jon-9 said. The adjust must be on the passenger side and the lock tab is imperative. Our '65 had been put together at some time with the adjuster on the driver's side and no lock tab. With the wheel turning direction and no lock tab the adjuster backed off and the axle got very loose not only destroying the bearing but damaging the axle as well. Fortunately, at the time, my 'guy" had two axles in very good condition in his inventory. We put one in the rear end and I bought the other as a spare. Good luck,
I installed 4-wheel disc brakes and had to go with "green bearings" on the axles. Maybe it's just me and I'm missing something, but I don't see that I'll ever mess with the stock bearings, seals, and the adjuster anymore. I never thought the stock setup was difficult to work with, but if these green bearings hold up, I feel they're just a better way to go. IMO
They are an easier way to go but, if you like to corner carve, then the tapered bearings are a better way to go. A single ball bearing per side doesn't take side loading as good as the tapered bearings do.
Yes, I completely agree. That's why I added "if they hold up" in my post. I feel they're a great option for most of us on here. I knew of them before they were required for my new brakes, I just never heard anyone's opinion of them or how they hold up in our cars. At this time I think they're awesome, when I finish the car (hopefully summer '25) and really start putting the miles on it (I probably only have a dozen miles on it), I hope they don't fail. Here's a picture of one of them on the axle. They feel like a solid, high quality bearing.
Had a 10.60 drag car in 84 with the Greens in it and they held up.....
