SuicideDoorLincoln
- Joined
- Dec 4, 2011
- Messages
- 124
- Reaction score
- 38
Here's one thing to consider when your going to install a cone, clutch, or gear type limited slip/posi. Some are going to have "drive shaft wind up" and others won't. Example: With both rear tires on the ground, trans in neutral, wheels blocked, and parking break set if you were to grab the drive shaft now and try to rotate it each way, it would be nearly impossible. The only slack you could feel or move would be the ring and pinion back lash, or any wear on the spider gears are cross pin... Now if you installed say a powertrax lok right, or a detroit tru trac you would be able to rotate the drive shaft a 1/2 or 3/4" each direction. That is the way they are designed as the gear or teeth bite into the case. The more torque put through the drive shaft makes the gears or teeth bite harder thus promoting lock up. I've installed numerous of these units in 9.25's , 9" fords, 10.50 sterlings, 8.5" gm's etc as I hate one wheel peels myself. If you go with a clutch type unit, it will be smooth, work great, no slop in the driveline. But the cons to a clutch type are : their not as strong as a gear type, some aren't rebuildable, and they cost alot more. I myself personally always go with a sure grip in the mopar 9.25 : because they set up so nicely , their a factory option so they are machined within a 1/2 a thousandth of an oe style open case, and their silent operation with no drive line slop. New bearings and races, swapping the ring gear onto the sure grip has always yielded the same gear tooth pattern and back lash readings as it was with the open carrier. I run the detroit tru tracs in my ford powerstrokes because they are manual trans so any drive line slop in hardly noticeable. Their tough, nearly unbreakable, aggressive , but not completely silent. I tried a powertrax lok right aka no slip system in a ford 9" and would never recommend one... They bite hard but their is always a racheting sound when turning and the drive line slop is horrible.... No surprise though as the install directions warned of this. I'm not sure what your cars daily use is but I personally would go for the sure grip, or one called an auburn gear which is clutch type. if you don't care about a bit of driveshaft wind up go for a tru trac. They have 3 gears on each side that bite into the case... Their not rebuildable, but ive yet to see one ever wear out. Stay way from the powertrax system which isn't a complete carrier replacement, it only replaces the side and spider gears.
