celticwarlock
I have a '69 NY with the stock A/C system that I successfully converted to 134a about a month and a half ago. Things are working well, and the air is cold, but I noticed something while it was idling in my driveway before leaving for Carlisle yesterday morning. Every 2 minutes or so, there would appear to be a bit of additional drag on the 2 belts. It only happened with the A/C on. This would last less than 30 seconds, then disappear. It was happening at regular intervals, so it didn't freak me out, but I thought I'd ask about it. Some background on the conversion for those who have not read my post from a few weeks ago: The RV2 was drained of mineral oil and cleaned out, the dryer was changed, the lines and condenser were blown out, the proper amount of ester oil was added to the compressor, all 3 Schrader valves were changed, the system was vacuumed down, and it was then filled with 134a at 70-75% of the original capacity for R12. The EPR valve was not removed because I do not have a thermostat probe to put into in the evaporator. I should also mention that this was originally an AutoTemp 1 car. The flow of antifreeze into the heater core has been disabled by a manual valve so I could get cold air when running the A/C.
Is this additional resistance normal? The compressor is on continuously (as it should be on this car), but as I said, there is this rhythmic cycle going on here that I'd like some insight on. It's not terribly noticeable, but it is there.
