GSPointer
This winter I bought a 40k mile then 40 year forgotten 64 Imperial. It took a lot of work to get it running and driving and stopping. Many leaks were fixed along the way but many remain. The biggest being a trans fluid leak due to a dried out and crumbly park brake cover gasket.
When I removed the cover, I didn't disconnect the cable from the pawl properly and I mangled a fine wire at the cable's end which I believe attached the cable to the pawl? Does anyone have a drawing or some words of wisdom explaining how to reattach this without further disassembly?
I have not removed the cable from the cover, the o-ring seems to be sealing, so if I can't fix this without further disassembly and a big adjusting project, can I drive it with the cable unconnected? i.e. Without the brake cable attached, is the trans brake engaged or disengaged?
