66furywagon
still r12 worked last year just fine nothing this year
all warm air freon is full
No sense even beginning a troubleshoot with about 10 questions 20 replies that need to be done yet.Screen in the oriface tube probably plugged with sealant?
What did you learn when you first Googled the Internet to try and solve your problem?still r12 worked last year just fine nothing this year
Roll the windows down in the summer problem solved.
i didnt google came here firstWhat did you learn when you first Googled the Internet to try and solve your problem?
http://www.aa1car.com/library/ac98.htm
Glad you found it. It's getting hot out there.One of the first things you should check, therefore, is compressor engagement. If the compressors magnetic clutch is not engaging when the A/C is turned on, the problem may be a blown fuse or a wiring problem
