Adhesive for vinyl side molding.
chry73luv
I have a 1973 Dodge Polara Spring Special with red body side moldings that have fallen off all the way around the car .I need to pull the chrome strips and reglue them .I need a really good adhesive to make them stick well.I hear that this red molding was a problem and the glue never stuck well. What would be the best product to use?
A roll of 3M Moulding "adhesive tape" in the correct width. Clean the surface of any wax/oil before applying. Should work better than a "hard" glue, I suspect, as it was OEM.
3m double sided tape. You must get all residue removed from the molding, and clean the paint real good or they will fall off in time again. Prepsol is a good cleaner.
