Advice on Cat Whicker Installation timing?
sprice
Winnipeg, Manitoba
Can or should the outside cat whickers be installed prior to window installation or after? (68' 300 Convertible)
I am having trouble with resistance with new run channel in the vent window assembly however reading more Mopar posts, it appears common and with new channels installed and takes some lubricant and up and down movement. I just didn't want to add to the resistance issue without knowing when to put the whiskers in. I will place the whiskers in, lube the tracks and work it up/down. Hopefully all settles in. Thanks to both.
