IF you can snap a mounting ear off of a carb, than means you don't have the correct OEM-spec carb base gasket under it! Reason I know? Back when I was driving my '70 DH43 "N" all the time, it seemed to get a bit harder to start after a hot soak period. I toyed with getting one of the Holley/GM heat shield base gaskets, but opted for a Mr. Gasket "stack" of gasket and aluminum plates. I figured that'd work better . . . but as I was gently torqueing the nuts on it, side to side and all of that, the compressibility of the gasket stack was more than the OEM gasket AND lacked the metal bushings in the stud holes, SO . . . I cracked the baseplate on the OEM AVS with just a 1/16 turn final tightening. Right in the area of the vac advance port for the distributor. So I bought a 4734S (replaced the 4732S OEM) and put the factory-spec base gasket with the metal bushing (to prevent such cracking upon torqueing-down) and called it "as good as it can be". End of story.
If the crack is not too bad, then some "sealer/putty" might work. Just be sure that you make sure the result is flat with a straight-edge when done.
