Analog Kid
Update here - I was able to adjust the ride height. The car felt much better and I felt there was more control. I'm still on the fence about the steering though. I feel like it could use some improvement but I don't feel like I'm losing control of the car. I wiggled all the connections to the steering box and everything seems tight. I am also not hearing any clunking which I would assume would mean a bad box. So after I feel confident about the alignment I might try to make some adjustments on the steering box and see how that feels.
Back to the alignment - I am a little confused on the specs for the camber. The FSM calls for a positive camber (Left side one quarter, right side one-half) but what I'm reading online (Mopar Action Alignment specs) states that you should have a negative camber. CBODY67 - you mentioned it should be around zero. I had put the cam bolts back in the same way they came out and if I check it with a level it looks like it is slightly negative. So I am wondering if I should ignore the FSM specs since they were based on bias ply tires and not radials. It sounds like having a negative camber might be better.
