70bigblockdodge
Problem on my Challenger. I have been fiddling with the tune on this car for a while.
Low compression 400 with cut down 516 casting heads @73cc, compression calculates out to 8.46:1
With a 284/484 Mopar cam
Wiend aluminum intake and headers
I have a lean spot in the RPM range idle to about 3300-3500
Engine has about 11" hg in park 1200 RPM and drops off to 8" in gear, I have played around with timing idle settings power valve.
So checking for vacuum leaks I found one in the hose to vacuum booster so I changed it no difference, plugged the port eliminating the booster no change, tried to draw a vacuum on the booster and I cannot get it to draw one. Reconnected booster ran engine at high idle 15" plus vacuum them **** off car and reconnect gauge and pump it sucked right to over 15"". My booster seems to work fine except for the bad vacuum from cam (you don't get multiple pumps at idle)
I think my little hand vacuum pump should still be able to pull a vacuum on the booster or maybe it is just a POS. I do not think the booster is bad but now it has me second guessing my self.
