live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,685
- Reaction score
- 8,888
Sunday night my daughter noticed that my volt gauge in the 68 NYer bounced around some on the way home from the grandparents. When we got home I put my meter on the battery and it was getting 14.8 volts.
Yesterday I was going to drive it to work when about 2 miles from home I noticed the gauge bounce radically, for instance from 10 - 16 volts, I don't know exactly. This is with one of FURYGT's regulators. I turned around and took it home. When I got last night I put another one of FURYGT's regulators on it. At first idling in the driveway I got 14.5. I went for a 20 minute drive to Wal-Mart and checked it there and I was at about 14.7.
Having yet another of FURYGT's regulators that was brand new I put it on this morning and drove it to work, 16 miles - 25 minutes. Almost watching the gauge more than the road, yikes... There was some movement in the gauge, but I saw no radical movement. Pulled it into the shop and put meter on it right away. This brand new regulator is putting out 14.9 volts.
This morning I pulled and cleaned battery terminals (small amount of corrosion), scuffed up the firewall where the regulator mounts, and cleaned the one wire that connects to the regulator (the other plugs on).
Does doing the ammeter bypass cause you to see a higher charging voltage at the battery? Is it somehow not allowing the voltage regulator to do it's job? Is there something else I should be looking at?
I honestly don't know how long it has been putting out this high of a charge. If my daughter had seen it bounce on our way home Sunday night I may not have noticed it.
I'm considering buying a regulator for a local parts store to see what it does. Try a different brand. It seems strange though I've gotten basically the same results from 3 regulators - hence why I'm questioning the bypass.
We're supposed to leave for Carlisle Thursday evening.
