WikedPlymouth
My 1958 Plymouth Belvedere has the 318 engine with a generator. The car is now running well, except for some blow by, but I've noticed on the aftermarket gauges I added that at anything above idle the battery is getting around 16 volts. Some times it even goes up to 17 volts. I've checked this with a digital meter on the battery. I know this is not good for the battery and wondering if it's just a bad voltage regulator or if there is anything else I should check? Thanks in advance.
