bronze turbine
Is this something that is important to do if everything in the car is factory stock? I've heard it should be done if you upgrade the alternator and start pulling a lot more amps than the factory wiring was designed for. I'm guessing the only reason they catch fire is because the connections on the ammeter get loose and get hot?
