Not the exact reading, but the resistance should read pretty low. Try taking an OHM meter so when you touch the 2 test leads together the needle reads zero (RX1)?
With both ends of the sender wire disconnected touch one lead to one end of the sender wire and the other to car ground and see it you get a reading. If you do this would indicate the wire is shorting to ground somewhere and needs replacing or finding that short along the wire.
A short or high resistance would foul up your gauge readings.:sign13:
