livininharrow
this is the crap I woke up to. but I guess the upside is I woke up to see it.
This is posted in the wrong section
It was originally in the "Website Suggestions" section which would probably trigger tons of input to joey, looks like he already moved it.I am confused as to what section it should be in if not general discussion?
hi shooter yes it is a 60. its a power wagon power giant. the guy I bought it from in Oregon a couple years back claims they only made 150 for the military as a prototype. its a 4 speed 4x4 with a 2 speed transfer case. not sure his claim is correct as I am not a powerwagon powergiant expert. hopefully you or someone knows more and can chime in. it is a BEAST. I could probably pull a loaded train with it. someone installed a later model 318 in it which is fine by me as the original would have been a flathead 6 .it runs smokes and drives. I have a Vintage Power Wagon catalogue that shows it to be a type G. 1957 to 1960 W100 or W 200 power giant. I am still trying to find the vin number which should be on the frame to properly identify it. will try to look again when the weather gets nice. no room in the garage. cheers PaulMore about the truck please, It looks like a 60. What size?
thanks for your time and all the info Shooter. I will check out those websites. the original winch and bracket were missing when I bought the truck unfortunately. thanks again. cheersBTW, if that's an actual Braden winch on the front, that's a pretty rare piece for Power Giants. Pretty common on WM300s but no so much for Power Giants.
