Newport 66
As seen on FaceBook...
Party pooperNothing new about this they have been around for sometime. Primarily designed to fit on pickups for remote areas providing more mobility. They usually end up destroying fenders from either coming apart or picking something up in the track and wedging between the fender and track. Also look closely at the front as you have limited clearance for steering. Looks neat but ends there. Most of them can be found in junk piles.
I try hard. Check this out American Track Truck - Car Truck & SUV Rubber Track SystemParty pooper
Ahhhh the fun you can have with a computer and the right software....
That's true, but the installation is definitely not finished, because they have to remove the bumper covers and trim them if they're going to use the track system. American Track makes a Dominator kit that can be used on most AWD platform vehicles. (Keyword is most.) Chances are the pictures are real, but they were likely taken in their shop during a mock up. I've seen them on Subarus, Nissan Rogues, Passats, etc.What do you think?... the first time he cuts the wheel those tracks are gonna take out either the fender behind or the year the bumper cover off in front. Depending which way he turns.
No it's not. The assembly is just bolted on in place of the standard wheels, and traction and steering is still done the same way.I wonder if steering is accomplished like a cat or tank or skid loader, whereas the track(s) is stopped in the direction you want to turn?
