Big block water pump housings
detmatt
Feedback: 29 / 0 / 0
The two at the top are pre '67 castings, the rest are '67 and later and the bottom one is obviously not like the rest. I have a couple of brackets to remove from a couple of them but otherwise they are as you see them. The water pumps wether seperate or still attached spin freely so I left them as I'm sure these parts were not removed from the cars because the water pump went bad.
asking $35 each + shipping from the Detroit area.:sFl_america2:
Haven't sold a one of these....
I keep a couple for if i pick up a block that is missing bits, thats about the only time you may need one.
I threw away a couple that I thought weren't worth selling, you never know...
A bunch, Nick. You got the heads, what else do you need??
Hey any of you guys got any performance exhaust manafolds for a 66 polara? also looking for max back spacing info for the rear ( experience )
thanks. Dave.
The bottom center (top picture ) one is most likely from a 400. Note how much smaller the
hole is in the center of the housing for return coolant. Know why?
thanks. Dave.
hi dave,i have a set from a 70 sport fury big block,if interested p.m. meP1020884.jpg
