Brake booster
The Swede
Sweden
Is it possible to upgrade a non power brake 65 Polara with a brake booster without any further modifications?
It's not too hard to do, the main issues will be to put in lengthened primary brake lines in. Your car has a dual reservoir master cylinder right? The other thing will be to put a vacuum fitting in the manifold to the vacuum hose to run to. Does your inlet manifold have a plug in it where one can go in?
