BoatMan
66 300 brake conversion under way. Spindles and donor parts are from a 69 Polara. Ordered bearings and rotors (1 piece) from local parts stores.
When putting the rotor on I have play. Seems like the spacing from bearing to bearing is too narrow causing the rotor to go back and forth ( maybe one sixteenth of an inch)
Races were already installed on rotors. However it seems like they could be further pressed in. On the rear you can see almost a quarter inch more that the ring could go down- same in the front.
Does anyone know how far in the bearings should be? What am I missing?
