Fred
Hello, I'm a new member, and I think I searched the brake forum for my problem, but cannot find it. I have a 62 Newport, manual brakes, and my brake pedal will not return to proper height, leaving the brake lights on. If I pull up on it, it stays up. I had this problem before, and it went away when I adjusted the brakes. I haven't really put any miles on it, and the pedal started doing the same thing. I adjusted the brakes again, but the pedal still won't return. I am thinking master cylinder, as I have only had the car a couple years, and the master looks pretty old. The previous owner replaced the wheel cylinders and shoes. Also, it seems to me that I have to really put a lot of pressure on it to bring it to a full stop. It doesn't pull, or make any noises, but it just seems like it takes more effort than needed. I had a semi-panic stop the other day, and I thought the wheels should have locked up, but none did. Thanks in advance, Fred.
