heyoldguy
Yep, and I'd be really interested in knowing how the cam was timed when it was installed.Why was it align honed?
Have you had it back to the track yet?
If so....ET and MPH results change any?
I was not able to have the block line honed on the original rebuild due to a lack of that service around my area. When the heads were off, I had the time to drive the block to a machinist 150 miles away and have it honed.
The cam was installed "straight up" per comps recommendation, I did not advance or retard it, save for whatever comp ground into the cam when it was manufactured.
Yes, the results are in the 1st post in this thread.
That's what we do, change subjects.How did we go from heads to transmission?
Any update here? I am amazed you're running in the 12s with only 230 degrees of duration and 3.23s. That's totally streetable.
I've thought about the same Stealth/505 combo but a hydraulic roller in the 218-220 duration range.
Your vid is currently my favorite on YouTube. Probably 50 of your views are me watching you smoke (literally) that 5.slow
I went 12.67@106 with a 1.72 60' time on a 105 degree day with 135 degree track temp at 3'. The trans was holding on the the shifts about a half second too long. I am sure there is more in it, my goal is 11.99's I am going back to the track in a month when its cooler.
I really like your video. The car hooks up real nice and stable. Would you care to share what you've done to it besides the engine and tranny?
Modifications to the rear axle?
