Carpet for my Fusy
MONC440
Michigan
Anybody order from stock interiors .com?
My questions are what is the correct style: 80-20? Also they have many shades of green. I was thinking the Olive green or dark green but can't really decide what will look the best with my seat combo shown below. Anybody have any pics in the car from this company in the green colors?
Thanks
@MONC440 -- if you post the fender tag of your car, then we can tell what the original carpet color was. Note that, if (not sure for a Plymouth) there is carpeting at the bottom of your doors, you'll want to be sure that it matches.
:BangHead: My build sheet and fender tag is gone. From everything I have seen it looks like F8 green so would that be the dark green?
Go to the "color and trim" selection and you can see some samples of what they used. Pick something close... or better yet, pick what you like.
AFAICT, your Fury is a SF. If so, then all the 1970 SF interiors were F8 -- see this specific page of the Hamtramck Registry Library that John recommended: The 1970 Hamtramck Registry - 1970 Plymouth Color & Trim Book - Fury
What I ordered off ACC website for my GT was the #30 Dark Olive Green which by their filter is correct and the only green option for 1970. I would recommend ordering without the mass backing and to do your own sound deadening, much easier to manipulate & form the carpet to the floor that way.
Finally my own '70 Sport Fury GT
Which reminds me I still need to order the 3 piece console carpet kit for my car lol. Looks like you have to search under B-bodys for that.
Personally I would scrap the carpet kit even the ones claiming to be the best from ACC because they never fit right. Ordered one and ended up pulling it back out only to take it to an upholstery shop who custom installed the same color loop style carpet that was properly fit and glued to my floorpan with padding for only $100 more than the kit cost me to have installed. I talked to multiple upholstery shops after ordering the molded carpet kit and they all said the same thing about the molded kits never fitting well.
Did you get the 80-20 loop?
Thanks
Just put the molded kit in my '65 and it was a pain in the A@*. It looks good and we had to do some modifications, but its in there now and looks good
Thanks c-barge
So your recommendation is 80-20, dark olive green, no backing? And order extra for my lower door panels and what not.
Yes, the extra backing made it a pain to contour and cut through. Would recommend laying down your own insulation for under the carpet tho.
