The "official" method to adjust the secondary air valve tension spring is to use a Carter special tool for such. When I had the TQ 9801 on the '67 Newport, I was trying to get the air valve tight enough to diminish a hesitation when the valve opened. I had been using a wide slot screwdriver to turn the outer ring and a thin slot screwdriver to do the middle screw.
With the spec'd adjustment tension, a bog when the air valve opened, no matter what. Probably needed to restrict the vac actuator's loss of vacuum, ala Rochester QJet? Anyway, that's how I discovered the fragility of that adjustment spring!
The Carter tool simplified that a bit, just needing the smaller slot screwdriver. BUT you can make that took, pretty much. Find the diameter of the larger item and get a piece of tubing that diameter and about 4" long. Then file one end such that there are two resultant tangs to index with the outer ring on fhe adjustment ring. Then deburr both ends for good measure. The original tool had a handle on each side of the non-tanged end, for ease of use, but you can just turn the tube instead, by hand. Still a two-handed operation, but not a tricky as with two screwdrivers.
