Classic air
Kippy
USA
Has anyone had a no heat issue with their classic air conversion? Im now on my third water valve. The first one was the metal body type and it malfunctioned, so I replaced it with the newer type plastic body one
Now recently I had no heat again after a couple of years and realized the valve was not opening. It had voltage to it and the ground was good. After back and forth with classic I had to purchase yet another valve and that one works properly.
I did have to on their advise recalibrate the system again which fixed a no defrost issue but not the heat issue.
So your system has computer-controlled actuators? Wondering if there's not a similar item in the OEM replacement lines somewhere?
I have their circa 2008 system in my charger, it uses the oem controls and microswitches triggered off the oem stuff. I had to replace one servo a couple years ago, only problem I had
