In the accompanying article you had mentioned that you added a 71 grill with retractable headlights. I believe you are using the 70 retractable set-up. I have both a 70 and a 71 Fury with each having retractable headlamp covers. The 71 also had a device which was a small brush which would swipe over the low beam headlamp as it was also applying washer fluid. Where the dealer had installed a clock mine came with an oil pressure gage. I wasn't sure about, nor have I ever seen a factory tach. Great article, and I was wondering just how much I was needing to take out of my IRA to get my convertible back to it's glory days from long ago. I had installed a 440-6 pack along with a limited slip, coupled with a rebuilt torqueflite including shift kit and 3500 RPM stall converter. Believe it or not I goy a whopping 5MPG.
