Coolant leak?
GORDON DREW
Kawartha Lakes, Ontario
I noticed this yesterday after i got back home. A wet spot under the car where the lower rad hose is. Coolant was down a bit, I tightened the clamp, i guess i wait n see if it has helped. Fingers are crossed
Look on the bottom side of the hose to see if a trail of coolant is coming out of the water pump shaft area. Might scout a new lower hose, for good measure, too.
Thanks for the advice, water pump area was dry it was concentrated by the rad and crossmember under the hose
