GORDON DREW
I noticed this yesterday after i got back home. A wet spot under the car where the lower rad hose is. Coolant was down a bit, I tightened the clamp, i guess i wait n see if it has helped. Fingers are crossed
Thanks for the advice, water pump area was dry it was concentrated by the rad and crossmember under the hoseLook on the bottom side of the hose to see if a trail of coolant is coming out of the water pump shaft area. Might scout a new lower hose, for good measure, too.
If there is no recovery bottle, it could be dumping excess coolant on the ground after shutdown. Cars of this era required a little air space between the coolant and the bottom of the filler neck.Coolant was down a bit
If I recall correctly my FSM says 1".If there is no recovery bottle, it could be dumping excess coolant on the ground after shutdown. Cars of this era required a little air space between the coolant and the bottom of the filler neck.
