This pertains to a 1967 727.
The lever shaft rotates through an arc, I'm eyeballing it at somewhere between 60 and 90 degrees. Some sort of internal spring keeps the resting position towards the front. As it's rotated CCW the resisting spring force increases.
I note some slack or slop in the CW rest position. Maybe 15 or 20 degrees worth. I can move it back and forth in that range with no resistance. Is that normal?
I read where this arm should move from fully CW to the full CCW postion in a way that follows the throttle position from idle to full throttle. The various rods can be adjusted for that. My question - does this include the slack? Should the slack be adjusted out at the idle throttle position?
I understand that this lever is pretty important and shouldn't be left disconnected, something about the trans internals not liking that very much. ?
