Mopar001
How to tell if the block is correct for the car?
That one had a stuck piston in it that I freed up with the 50/50 acetone and trans fluid mix. I then had it hot tanked, magnafluxed and measured to still be a good useable block which is original to this car.
the top of my block says this:
F440 0
3 31 HP2
Yep, still have it, still for sale and much cheaper!Hey Matt, is that the Challenger A66 that was for sale on Cuda-Challenger forum a couple of years ago?
F440 0
3 31 HP2
Dont go boring the engine block if it only has slight wear, this way you get more life out of it before actually needing to be bored for a second lease on use.Im going to take another look at the block today for the VIN numbers. The funny thing is, when I sanded the valve covers to paint them, the under coat is the mopar green??? and I can see some green paint mixed in with Hemi Orange on the side of the block through all the dirt oil and grime.. weird.... I have the heads off and am going to get them refinished. the cylinder walls show some ware but no scaring. inside the engine is VERY clean. NO gunk built up anywhere. Some of the rockers are warn down. Two of them were rubbing the inside of the valve covers. that's how warn down they are...
