Biggredd2069
So I got my 68 Newport convertible 383 4 barrel about 7 months ago. Been a winter project getting it back into shape. There were some wires in the steering wiring harness that were old and broken and I also conveniently broke my turn signal cam. I bought the new harness and installed it. Successfully working so far as I can tell. I haven't been able to test the cruise control due to all the projects I've been doing. In the meantime I was having some hesitation when I was flooring the engine from a stop. I had a leak in my intake manifold gasket which I got replaced and they said your carb could use a rebuild. So I went ahead and paid for that too. Well I was still having hesitations in the motor. So more delays testing other things. when I brought it back for a second look they ended up swapping out my carter with an edelbrock 650 and electric choke they had. They advised I was missing some spring in the other one and they didn't charge me. (glad they could've found that out the first time). Well its running good now but I've been trying to get leaks fixed too so the day I got it back I started to take the valve covers off to put new gaskets on and paint the covers. So long story short when I got the air cleaner off I noticed the cruise control cable just sitting unattached under the air cleaner next to the carb. I have an original AC car that was taken apart for some reason from previous owner, I have the parts but isn't hooked up. So I'm in an internal debate to get pissed off at the shop for one more thing not done right, did they not hook it up or was it already not hooked up from the previous owner dismantling a few things and probably wasn't working anyways from the broken wires behind the steering wheel. So I was reading another thread about trouble hooking up a cruise control to an edelbrock. My goal is to get the cruise and eventually AC, and everything in general back to working condition. Anyone know if the following applies here?
I received a call and a fix from Edelbrock for mounting the cruise control cable. He said that he's worked for Eddie for 20 years and I'm the first person ever to call about this dilemma for a Chrysler. The fix is part number 8009. I looked it up and it's an accelerator cable adapter for a 1977 and up chevy. It looks like it should work. Eddie is going to send me one. It is also available for $4.99 at Jegs.
Edelbrock 8009: Throttle Cable Adapter Stud 1977-Up Chevy | JEGS
