Cruise Control Quit Working
The_Eagles’_Nest
Gurnee, IL
So as the title says, that’s my problem. The 72 Imperial cruise control quit working. I have a known good switch I swapped out and that did not bring it back. I was trying to test for power going into the servo and can’t seem to find a wire labeled as the power wire going into the switch or the servo. Which wire would it be?
Take a look at this. Browse MTSC by Model Year – 1972 – MyMopar Download 72-9 and watch the corresponding video.
There's also this from FCBO A guide to your Speed Control Servo
I attached a PDF of a Mitchell repair guide that may help.
  • Speed Control.pdf
Did you check the brake light switch? That turns on/off the power.
